I have no idea what I’m doing
Orville1nelson
2
Killeen
Just moved into this house with a pool I drained it because it was dull of mosquitos and hulk green water I don’t know how any of this works or what I need to do to fill it up no cracks in it or anything I just need help
mknauss
52,089
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
Welcome to the forum!
First thing you want to do is get water in that pool! It appears to be a fiberglass pool and that can pop out of the ground very easily!
Next is to add chlorine. Add 5 ppm FC worth of liquid chlorine while you are waiting on your test kit.
You need a proper test kit, see Test Kits Compared. I suggest the TF100. A proper test kit is needed to get the accurate water chemistry results needed to follow the TFP protocols.
I suggest you read ABC's of Pool Water Chemistry.
Post some more questions once you absorb that.
Orville1nelson
2
Killeen
Do you have any idea on how the pump works or anything like that
mknauss
52,089
Laughlin, NV
Fiberglass
Post some pictures of your equipment pad. Close ups and shots with everything shown. We will take a look, ask some questions, and walk you through it.
Do you know if the equipment operates?
