I have a Pentair VSF. Is there a way to shut off schedules.
Chuckiechan
471
Roseville, CA
I had everything dialed in for the summer. In the winter everything needs to change. I only need one program at one speed for “X” hours. Do I just manually reset everything?
What do most people do?
1poolman1
In The Industry
Jul 14, 2014
65
Sacramento
When you enter the menu of each speed you are given the option of setting speeds in "egg timer," "manual," or "schedule" mode. Depending on the age of your pump the options may vary slightly. Just set the speeds you don't want to use to "manual" and they won't operate unless you push the correct button.
Reactions: Chuckiechan
