Hello Everyone,
I grew up on a farm in West Tennessee. When I got old enough, I joined the Navy. After 6 years, I got out and went to Purdue to get a BS in Computer & Electrical Engineering.
Last year, I finished building a VERY, VERY unusual house with an indoor pool. (no water yet)
When I say that "I built it", I don't mean I hired a builder and crew to build it, I mean I literally designed and built it myself. I did hire a plumber and HVAC guy to do those things. I did the rest.
I did hire some people to help me do some of the larger manual labor tasks, like placing concrete for the slabs and driveway.
(almost impossible for one person to do those things by themself)
Before I installed the flat concrete roof, a crane operator lowered a 14x30 fiberglass shell into a carefully contoured hole on the 2nd floor to accommodate the shell.
I then plumbed the shell and back-filled the empty space around it with crushed gravel. I bonded the pool and decking rebar, then placed coping forms on the shell and poured my concrete decking.
Since there was no water in the shell, in order to keep the walls from bulging inward from the pressure from the back-fill gravel, I placed sheets of OSB along the interior walls of the shell and placed support bracing between opposing walls to keep them from collapsing inward. Once I fill it with water, I will no longer need the support bracing and they can simply be removed.
Since I designed and built this house myself on a tight budget, I've had to prioritize all tasks to fit my schedule and cash flow (income).
After 4 years of hard work, I have finally worked my way down that prioritized list to getting the pool ready to open.
I am now researching which pump, filter, and water "sanitizer/purifier/disinfectant" system to purchase.
Currently, I am leaning towards purchasing a good quality name-brand (expensive) variable speed pump and large cartridge filter to match my size pool.
As for the water "sanitizer/purifier/disinfectant" system, I would like to avoid using chlorine. (obviously that includes salt water systems)
I realize that this goes against most members' belief that chlorine is the only way to go, and I *DO* realize that I may have to resort to using a small amount of chlorine at times, but I am trying to avoid using chlorine for all of the obvious reasons.
I believe that chlorine and especially it's by-products even in small amounts are not good for you and should be avoided, if at all possible. (again, my humble opinion and belief)
Besides, being indoors and currently with little to no ventilation, a chlorinated pool will likely fill the room with that well-known odor and could even be dangerous to breath.
Yes, I am considering different alternatives to provide conditioned (heat/cool/dehumidify) air and fresh air ventilation to the pool room.
I have looked at *SO MANY* of those "chlorine-free" systems which typically use electrolysis with various element rods (titanium, copper, silver, etc.). Most of them mention "NASA-based" technology.
I have read *SO MANY* testimonials where people either *LOVE* or *HATE* every one of them.
When I designed and built this house, I PURPOSEFULLY isolated the pool room from the rest of the house and it's HVAC central air system. For access to the pool room from the interior, I installed an exterior door with good gasket seals to prevent any air leakage. In all the walls, I placed insulation and a GOOD quality vapor barrier on the INTERIOR (pool side) of the walls. The pool room is COMPLETELY hermetically sealed from the rest of the house. I added 3 large triple-pane argon-filled windows along the exterior wall to provide additional lighting and ambiance. When we can afford it, I plan to install a 20' long "accordion" folding glass door in the Southern exterior wall. This will allow sunlight to come in during the Winter and provide some heat to the water, which I can then use to help heat the house. (the pool pump will be located in my HVAC utility closet where the water will be heated/cooled by my custom "one-of-a-kind" geothermal heatpump. In addition to providing central air conditioning, the heatpump also heats the domestic hot water tank and radiant floor heating water tank.)
BTW, I see several key advantages to having a pool indoors:
- There should be almost *NO* debris in my skimmer basket or filter!
- I won't have to worry as much about evaporation
- The sun and rain won't mess-up the water chemistry
- We should be able to swim any time of day or night, year around!
- I should never have to "close" or "re-open" the pool
Sorry for my long-winded post. I actually left out a *TON* of details!
I welcome any and all advice.
I would post pictures, but I'm currently storing wood boards for shelving and trim in the pool room, so it's not pretty. (It's my temporary shop until I open the pool)
Anyway, I look forward to reading different posts and learning all I can about caring for a pool. (I've got a *LOT* to learn! You almost have to be a chemist!)
