Hi,
I'm not a new pool owner. I had a huge pool years ago and filled it with well water and never had the trouble I'm having now with a much smaller pool. I've this pool a month and haven't been able to get in it, yet! Not all of it is due to chemical imbalance or well water, WEATHER! Gosh, it's rained so much here in Indiana I feel like a duck! I didn't know how bad my well water was!! I have the pool clear and the chemicals are all correct, but if you look down at the bottom you can see where all the rust has settled. It's so fine that if you try to vacuum it with the water hose method it goes right through the mesh bag. Then I put white one sock on it. That worked ok, but still dusted the water. Then I tried 3 socks at once. That did a little better, but still was dusting the water. My vacuum that hooks to the skimmer, blah blah blah won't keep the suction. I don't know if the hose is too long or what. I have a 15' x 42" Intex quick set pool. The normal pool hoses you buy are 24'. I've not found any other sizes. I've done the filling it up with water bit and so forth. Nothing seems to work. I guess I'm going to have to resort to buying a sand filter.
