Hydration Stains?
Bevgrat
16
North Port Florida
I am reaching out as we are at our wits end with our pool stain. A little background, our pool is 18 months old, salt water, source water is well, 7800 gallons, quartz finish, Hayward heater. Grey stains started appearing in the deep end about 6 months, our pool installer in FL came and spot acid washed, spots lightened, several months later more appeared, now they drained pool, torched and acid washed. About 2-3 months after that they came back and continue to increase. Now a tech from the quartz company had us put Jack magic purple stuff in for 2 months and testing daily to keep alkaline, chlorine etc at his suggested numbers, still nothing happening to the stains. As that could be expected now no one will call us back. Now we are trying the CULator program and just added the Periodic metal stain eliminator kit, another $100 later and nothing. I’m hoping someone has had this issue and be of some help as all the forum we read there doesn’t seem to be a solution to our problem.1605384101565.jpegf1605384101457.jpeg1605384101565.jpeg
YippeeSkippy
15,137
Evans, Georgia
Bevgrat, welcome to Trouble Free Pools :)
Sorry to hear about these problems. So you fill with well water, right? Do you know if you have metals in your water? I'm sorry to say we've never heard of particularly good results with the CUlator.
What is your current chemistry and are you testing yourself or relying on a pool store? Can you tell us:
FC
CC
pH
TA
CH
CYA
Salt level
What other chemicals have you or the pool builder put in your pool??
A thread that discusses hydration stains-
Maddie :flower:
Bevgrat
16
North Port Florida
Merged threads. TFP Mod.
FC .41-TC.41-PH 7.6-TA 104-CH 303- CA 38-Iron.2-Copper 0-Pho’s 0- Salt 3086 we test and pool accu blue test.
We filled pool with the water softener water not directly from well.
We can drive out metal stains as Jack’s magic and CuLator programs didn’t even lighten the stains.
JJ_Tex
2,156
Prosper, TX (DFW)
Wow, sorry you are having to go through that. I know nothing about stains, but it seems like step 1 would be identifying the stain type vs just randomly treating.
Luckily there is an article on pool school for you. Start here, and pay special attention to the section on iron stains since you are on a well and have iron show up in your test.
Reactions: setsailsoon
JamesW
21,934
It looks like it might be copper.
If you have a cartridge filter, can you remove the cartridge and show a picture of it before you clean it?
Drop some vitamin C tabs on a spot to see if anything happens.
Do you know if copper is in the water?
What's going on with the deck, why is it black?
Do you have pictures of the original look of the deck and plaster?
Bevgrat
16
North Port Florida
We tried a lot of citrus acid-vitamin C and nothing. No copper and last accu check showed iron at .2 The deck is grey pavers that were sealed so in the shade appears black.
Bevgrat
16
North Port Florida
JamesW
21,934
It looks like it could be copper to me. Get some regular vitamin C tablets and drop them on a spot to see if anything happens.
The only other thing that I can think of to try is Jack’s #2 copper and scale stuff, which is sulfamic acid.
Do you have a cartridge filter?
Bevgrat
16
North Port Florida
Yes we have a Hayward cartridge filter and all water test shows no copper.
JamesW
21,934
If it works, you will need to drain and refill to get rid of the copper.
Note: Don't drain without getting a local professional to approve because the pool could float when drained.
JamesW
21,934
Can you go pull out the cartridge and show a picture?
When was the last time you cleaned the cartridge?
Was there any green color?
Note that copper tests that come back negative don't necessarily mean no copper.
If most of the copper is in the plaster, it won't show up on the tests.
Bevgrat
16
North Port Florida
We brush every day and clean filter at least every 3rd day and it’s never green. It’s usually just a grey color. We already tried the vitamin C & citric acid right on the stain and didn’t do anything.
JamesW
21,934
OK, in my opinion, it's probably copper.
The pool started out white and now it's turquoise and grey. If there was no turquoise, and the stains were only grey, I would not think that it's copper.
The look is classic copper stains.
If you're out of ideas, I would try sulfamic acid.
JamesW
21,934
That's unusual. Most people only clean their cartridge a few times a year at most. Why do you need to do it every three days?
I would still like to see the cartridge if you can show a picture.
Reactions: Kellyp
JamesW
21,934
Vitamin C is ascorbic acid, not citric acid.
Get a handful of vitamin C tabs and drop them on a spot to see if anything happens.
Leave the tabs sitting undisturbed for at least an hour.
Bevgrat
16
North Port Florida
We have put citric acid in twice and absorbing acid, muriactic acid we add to lower the ph. We have not tried sulfuric acid.
