Hey y'all,
Grew up with a pool so know basics but just bought a house with a neglected hybrid pool (concrete bottom/fiberglass walls). Seller disclosed a "$1k leak coming from the steps" but I am doing due diligence to ensure everything is good.
What I've done so far:
Current problems:
Any feedback is appreciated, is a replaster a good idea? Should I re-caulk before I fill back up? I want to mitigate any additional damage if possible (especially if the leak is significant)
Thanks a bunch!
Josh
- Drained algae-infested water
- Replaced about 1000 gallons of fresh, chlorinated water
Current problems:
- Concrete appears to be peeking through the plaster in some places on steps. How critical is this?
- Joint caulking between wall and floor is peeling in places and cracking. Unsure on the remaining life?
- Noticed bubbles coming from a joint as seen in this video. Oddly enough, the food coloring did not want to go into the hole. What is causing this?
- Pool deck exhibiting a large concrete face missing with hairline crack in floor, possibly from recent winter freeze? How critical is this?
Thanks a bunch!
Josh
