Hum from skimmers
Debigold
Active member
Jul 1, 2018
32
San Juan Capistrano, CA
Hello Everyone,
A new summer comes a new issue. Just started yesterday. When the vaccum is running a hum comes from the skimmers, but when the vaccum not running no hum. When we rwmove half the hose links no hum, but adding the hose links back it hums. We are dumbfounded and baffled🤣 Any ideas?
Debigold
Active member
Jul 1, 2018
32
I’ll go with leaves, needles or other debris stuck in one of the sections. You’ve already got it half narrowed down. :)
Thanks, but nothing in any of the hose sections or the vaccum. We even put a new vaccum on the end and as soon as we plug the other end into the skimmer we hear that humming from both skimmers. Poltergeist?
Newdude
14,578
NY
hear it mostly through the other skimmer. Never heard this before
That changes everything. Try the flapper that you close to get better suction on the vac side. There should be a Phillips screw holding the flapper thingy tight. Maybe it’s loose and the flapper is a flappin
