How was this done?
Andrew_D
150
Manitoba, Canada
Hayward Salt & Swim 3C
The pic of the end wall with 2 ports: These are 2 that I added. I use the original pump/filter that came with the pool to run the solar panels through these ports. I just have the pump on a block heater timer. Cuts in at 8am-ish and out at 7pm-ish. Nice and simple and no controllers to mess with!
On the side wall, you can see the original 2 ports that came with the pool. Both of these have been upgraded to a standard 1.5" hayward return. You can also see the skimmer that was added. The one closest to the skimmer is plumbed as a suction port. I leave the valve cracked open a bit because people splashing, or wind, etc can make the skimmer gulp air. Having the valve on this sidewall suction open halfway or so allows another path for water. Seems to work doing that! Also on this sidewall, you can see the RH return. I am also looking at adding a 2nd return. Either further down that side, or on the other end.
Andrew
Lesmon
10
South Caribbean.
Intex Krystal Clear
Many thanks Andrew_D, CowboyCasey, Dirk and all the others that contributed on th his thread. This community really works.
Today, I will be out shopping for my hard piping part of the project which I will be starting tomorrow, at least to relocate the pump and SWG. Wish me luck.
Lesmon
10
South Caribbean.
Intex Krystal Clear
Well, 2 weeks later and think i got most of it done, all working and no leaks. Took longer than i thought, but well worth it. Got skimmer installed (higher than most i saw here), fountain, and pump and swg in pump room.
Thoughts, comments and feedback would be welcomed.
Now to go build a deck😉.
20210202_101639.jpg20210202_101647.jpg20210202_102108.jpg20210202_102537.jpg20210202_102346.jpg
Lesmon
10
South Caribbean.
Intex Krystal Clear
Oh yes, just need to change out the 2 flex hoses in the pump room...to really call this phase completed.
cowboycasey
7,619
Southern OK
CircuPool SJ-40
Nicely done, I LIKE :)
Congrats :cheers:
PieterS
67
Minneapolis, MN
Andrew
OK - love your snowy pics. I think you just answered my question on whether I can just leave my 16' round Intex up year-round in Minnesota rather than taking it down :)
Dirk
8,624
Central California
Pentair Intellichlor IC-40
I'm so sorry to rain on this parade... because you did a very neat job. All those elbow and tee fittings appear to be DWV fittings (drain, waste and vent), which are not pressure rated and shouldn't be used in pool plumbing. They're for no-pressure, gravity-feed applications, like sink drains. That's the official line. Will it ever matter? Or come apart?
The glaring differences between a DWV fitting and a schedule 40 pressure fitting are:
- The amount of glue surface, and
- The way the tee's ports connect (one is straight in, the other sweeps in)
I understand the idea of replacing all those fittings would be unthinkable, but I'd be remiss if I didn't point it out, as you want your system to be safe. So you've got some thinking to do on that...
Reactions: Andrew_D
cowboycasey
7,619
Southern OK
CircuPool SJ-40
@Dirk I so missed the fitting, thanks for catching it...
Lesmon
10
South Caribbean.
Intex Krystal Clear
Just looked at the Vid. Schoolboy error on my part, didnt know the difference. My neighbour runs a hardware store and sent me all the pipework and fittings - i just assumed it was all ok. Just counted, i have some 50 tees, elbows and 45s in my setup😥😪.
Will need to keep an eye and change out when they give up. Shame. And was so proud of my work, but learnt something new today🙄.
Lesmon
10
South Caribbean.
Intex Krystal Clear
Any comments on the setup of the skimmer? Notice how high it is on the pool side, about 1.5 inches higher tham most i see here,
but allows the skimming, and kept the core strength of the pool.
cowboycasey
7,619
Southern OK
CircuPool SJ-40
The skimmer is a little higher but it should be just fine, the water level will be about an inch higher in your setup that's all :)
Dirk
8,624
Central California
Ugh, that sucks. It's understandable that you didn't know about this. It's actually seen a lot here, it's a common mistake. But a hardware store owner should have known the difference. Perhaps he can offer replacements for his error, or at least a substantial discount on the next set.
The only problem with that is what can happen depending on how it fails. It's just as likely to be catastrophic as it is to be a small leak. If one of the joints on the ground gives way, for example, you'll come home to a half-empty pool and a flooded yard and possibly a burned out pump (the pool could drain to the lowest fitting). Or course, if it all runs into your hardware-store-ownin' neighbor's yard, that would be just! (Sorry, too soon to joke...)
Those joints might hold forever, or one of them might give out today. It's a tough call...
Well you should be. You did a great job on the layout and the fitting. All nice and neat and straight. Better than most plumbers would do it.
Dirk
8,624
Central California
The skimmer determines where your water level needs to be. Typically the water level should be halfway up the skimmer's opening. If that's where you filled it to, and the water level is OK for the pool, then your skimmer location is A-OK. I noticed the skimmer frame overlaps what looks to be ridges on the wall. As long as that sealed up nice and water tight, you're good-to-go.
