If there are two holes at the bottom of the skimmer housing, you may be able to get a hose to connect the open one to the other (which probably has a cover on it). The second hole should run to the floor drain in the pool. The little hose will probably be cheaper than a submersible pump, although the pump may have other uses for you and be simpler to deploy.
