how to treat after a hot tub party
joecooler
116
Longmont, CO
So my kid had 6 of his closest friends over for a party in the hot tub. I decided to proactively hit it w/an extra dose of chlorine in advance. I assume this must have been a good idea as the water still looks clean the morning after. BUT when I run the jets I quickly get a big head of foam on the surface - more than I've ever seen. When the foam starts to dissipate I can see an oily skin on the water. What is the right way to get the water 100% clean again - clarifier, shock, or more chlorine?
Thanks in advance!
JoyfulNoise
Platinum Supporter
May 23, 2015
15,864
Please post test results. How old is the water and when was the tub’s plumbing last purged?
If oils are present you may need to use something like a ScumBug to soak them up off the surface first. Clarifiers are not a good idea at this point. Chlorine will decinitely be needed but you want to be careful not to create a lot of chloramines by adding too much.
Reactions: joecooler
joecooler
116
Longmont, CO
I don't have my test kit yet so my results would just be off the dip stick ... is this useful?
Hardness ~250
TC ~2
FC ~1
pH ~7.6
TA ~120
Water is two months old. How do I know if I'm creating chloramines, and what would be the bad side effects if I do?
joecooler
116
Longmont, CO
Also FYI in case you didn't see my other thread, spa is just two months old, this is the first fill, and I didn't know about ahh-some when I filled it so I haven't run a purge/clean cycle yet. Planning on doing that when it's time to dump this water.
JoyfulNoise
Platinum Supporter
May 23, 2015
15,864
Purge it with Ahh-Some, dump it and start over. Honestly, the water is cheap and not worth it.
Chloramines are created anytime you add chlorine to water with a high organic load to it. Nitrogenous waste from humans, aka bather waste, contains lots of sweat which is full of urea, creatinine and other amine containing chemicals. When chlorine hits that stuff, it creates both inorganic chloramines (mono- & dichloramine as well as nitrogen trichloride) and organic chloramines (chlorourea, etc, etc). The inorganic chloramines will go away over time through outgassing and further oxidation from chlorine. Organic chloramines are persistent pollutants and build up over time. Hot tubs will often have low CC readings at first but then, as the water ages, the CC readings creep up and cannot be removed with superchlorination. It's at that point when you should change the water out. Spa shops will try to sell you non-chlorine shock but that's just a band-aid and often causes more trouble than it's worth. Water is cheap enough and hot tubs are low enough volumes that it just makes sense to dump it and start over.
I'll wait for real test results but I suggest purging and dumping....
joecooler
116
Longmont, CO
I will purge as soon as possible, however not sure how soon I can get to it ... may be a couple of weeks. Until then should I do anything else to the water? Can I keep using it?
Re/ahh-some, I plan to purge, refill, and clean a second time to be sure I get everything - want to start out w/a nice, verified clean tub. For the second purge do I need to do all the stuff to the water - adjust hardness, alkalinity, etc - or can I just fill it, throw the ahh-some in, then empty and clean, and wait to do all the balancing until I plan to keep the water?
JoyfulNoise
Platinum Supporter
May 23, 2015
15,864
Honestly, one purge, done correctly, will be more than enough. There's a user here on TFP, @Ahhsomeguy , who's actually the president of the company that makes Ahh-some. Even he will tell you that all you need is one purge. And he's very happy to help all of his customers.
You can use the tub. Definitely chlorinate it though. Follow the directions in the forum sticky on "How to use chlorine in a hot tub" and it will give you all the correct levels. The oils and human "scum" may take some time to clear out since filtration in a hot tub is generally not that great. Try getting one of those Scum-Bug things to help soak up the oily "fluids" floating on top.....and just remember, there were bunch of kids in there so lord only knows what they left behind :sick::poop::alien:
joecooler
116
Longmont, CO
OK, cool, thanks for the help! Good to know about the purge. And, yeah, 7 college students (4 boys, 3 girls), in a 6 person hot tub. I don't even want to think about it. :-D
Oly
1,168
Fresno, CA
Most likely body lotions and hair conditioner products from not showering before entering the tub. Let's hope that's all.....:oops::laughblue:
Kick up your sanitizer level before the purge and be sure to rinse the tub and plumbing well after the purge to remove all the surfactant prior to filling and heating.
Oly
1,168
Fresno, CA
You will need a proper test kit to test for CC, combined chlorine. Easy to do and an important test especially for hot tubs and spas.
Getting above 1 to 1.5ppm CC is a concern.
joecooler
116
Longmont, CO
OK. I've been holding off on the test kit but clearly i need to pull the trigger on that, some ahh-some, and a scum buddy or two. Thanks again for all the help - you guys rock!
YippeeSkippy
11,522
Evans, Georgia
Let's see ... your title says "How to Treat After a Hot Tub Party" and your first line was -
So you'll just have to forgive me when I say my first mental response was "penicillin!". :laughblue:
A friend had the same experience time and again and found her son's friends were often entering the hot tub in clothing, which can contain detergent/soap/fabric softener residue. Those will foam up a lot.
I'd be looking to give the hot tub a lot of chlorine bleach to oxidize things, and perhaps a bit of calcium which can decrease foaming.
Maddie :flower:
YippeeSkippy
11,522
Evans, Georgia
You will love (in a grossed out way) using that Ahh-some for the first time! Ugh...the crud it spews out of your pipes is amazing. Take a pic for us o_O
Good call on the kit.
Maddie :flower:
