Moved from Here
My Intex also has a couple legs starting to lean away from vertical. Did jacking it up and tapping it back work? Worried once weight is taken off it will push all the way over. And does the bottom of the leg need to be adjusted too? Was told to dig it out and check before trying to tap it back. Thanks.It appears I have one leg that is way more crooked than the others, and wonder if there's any options whatsoever to straighten it even though the pool is full. is there some sort of jack where i can take a bit of pressure off one of the straight bars enough to straighten and relevel that leg? or should i just leave it.
