I believe it is time for a new salt cell. Is it as easy as just removing the old cell and screwing the new one in? Or is there anything I need to do after I put the new one in place? Thank you.
Usually if it is the same exact cell. What cell is it? Why are you replacing it? Salt cell's are a "use them until they don't work at all anymore" and not something you should replace if you are not having an issue.
While your cell may be bad, it may not... Tell us what kind of cell and what problems you are having.. It may just be something making the cell "look" like it is bad..
Last November my Aqua Rite board was showing low salt so I added salt. It went up but then a week later came down. It kept going down. Then bouncing back up. The salt cell is almost 6 years old so someone told me it was probably a bad cell. I got it working correctly and now about 6 months later the Aqua Rite board is showing salt level dropping again, today registering at 2200 which I know is not correct. I bought some salt strips and for a few weeks in a row they are showing salt steady at 3700. We have removed the cell several times and the board is still showing "low salt" and not generating. My FC is also now dropping leading me to believe the salt cell is dying or dead:
April 11 - 6.5
May 20 - 4.5
May 26 - 2.5
So I am thinking it is the salt cell. Any other ideas? Thank you!
Here are the diagnostics. Last November when I first had issues the board switched to metric and I have not been able to switch it back:
2.30
24
31.3
0.00
38P
-0.00
AL -0
r 1.59
L - 15
When I switch it off some of the numbers are different but then in a few minutes all switch back to what is showing above. Thanks for any insight or ideas.
