How to protect exposed liner until fill?
ToddGak
Active member
May 19, 2018
32
Saratoga Springs, NY
Over the winter, my above ground pool’s water level dropped significantly. I assume there is a leak, that I have yet to find, but that’s another issue.
I am on well water and can’t fill the pool myself. I called the local pool fill companies and the earliest I could schedule the fill is almost two weeks from now.
Right now, the pool level is about 1.5 ft, so a significant amount of liner is exposed. I know you shouldn’t empty an AG pool because the liner can shrink in the sun and be destroyed. Will I be ok with this amount of water, or do I need to do something to try to protect the liner?
Should I put the winter cover back on?
Casey
11,993
SW PA
Fiberglass
Jandy Aquapure 1400
If I'm reading this right, you have 1 1/2 ft of water in the pool? Dont worry about it. As long as the floor is covered with water, it should be fine. If I were you, I'd try to combat any algae blooms by adding a little chlorine daily and brushing the pool until you can get it filled. It wont stop debris from accumulating but itll keep it clear.
kimkats
48,713
Tallahassee, FL
I would put a cover over the top just to keep the sun rays off. It can't hurt anything but do like Casey said and add some chlorine each day and brush it to mix it up.
