How to program both heat and cool (heat pump) through Pentair ScreenLogic?
KingpenM3
Active member
Jul 2, 2020
26
Louisiana
I might not be seeing an obvious option, but I'm not sure how to program my heat pump to switch over to cooling for the pool during the day, and then back to heat for the spa in the evening. Thanks for any input.
Jimrahbe
27,613
Bedford, TX
M3,
I'll say right up front, that I don't have a heat pump, so I could be full of it... :mrgreen:
That said, I doubt ScreenLogic is going to tell the heat pump to switch to heat or cool... I suspect all ScreenLogic does is to tell the heat pump what the set point temperature should be..
If you want to have a different set point for the daytime and nighttime, then you just need to set up two schedules.. One with your daytime set point and one with you night time set point
You also have to make sure that ScreenLogic knows you want cooling on the configuration set up pages..
That's my story and I'm sticking to it, unless I am wrong... :rolleyes: Which I was... See JamesW's post # 6...
