Ok...I'm frustrated with finding a solution to drain water from my pool. It's an inground pool and has a mesh cover. We get so much rain and snow melt all winter that I have to continually drain it or it will overflow. And, I don't like knowing the water is above the bottom of the skimmer because we also get freezes.
It is definitely easiest to drain from the skimmer lid but that doesn't leave much room to work with. Sliding a submersible pump under the tight cover and down into the pool is not easy.
I have a hill behind the skimmer side but starting a siphon is not easy either (not sure how to do it).
Ideally, I would like to have a pump that is not submersible (with intake and output hoses on each side) that I can just leave on the deck. It's not easy getting electric out there either so I would love it if I could find one that can be removed once it gets a siphon going.
Thoughts???
Thoughts???
