How to convert to LED COLOR lights
Jul 9, 2012
9
Looking to remove old spa and pool light( incandescent 12V) to color changing LED lights that will be compatible with Penair Easy touch. The old lights in spa were sta brite and I think the pool is Pentair. Question is it as easy to remove old lights and reinstall new? Are there aftermarket brands that will work too? With the easy touch system do I need a controller or does it work as is?
In the Easytouch, you just change the light type to Intellibrite or whatever light you get that is compatible. Then the ET will know it is a color changing light.
