How to Balance a 16,000 Gallon Fiberglass Pool
nymickey
15
Marietta, GA
I apologize on the front end if this is posted in the wrong place.
Greetings and Salutations,
I just had my water tested and the computer spit out the results below.
I think the water looks fine (we have a salt water generator) but the numbers do not look good at all.
Can you please advise what I need, the order that I do it and the timing of each chemical.
Gallons = 16,000
Filter = Sand
Type = Fiberglass
Free Chlorine = 1.12
Total Chlorine = 1.15
pH = 7.9
Total Alkalinity = 83
Calcium Hardness = 155
Cyanuric Acid = 43
Iron = .4
Copper = 1.3
Phosphates = 858
Salt = 1,807
tim5055
10,736
Franklin, NC
What does your K-2006 test kit say?
We never make recommendations for chemical additions based on pool store testing.
But, the thing that jumps out at me is teh copper. Do you have a heater or have you used algecides in the water?
