how to attach a file from my iphone to this forum?
ajw22
5,417
Northern NJ
Middle of the editor tool bar, in between the the paperclip insert link and the camera icon there is the Insert Image. tap that.
Leebo
Admin
8,372
Eastern Ohio
What type of file might I ask? For a photo you’ll upload using the steps Allen mentioned. For other files you’ll see an “Insert Files” button right above the Post Reply. Click that and upload.
garygaugler
23
Arizona
Hi: as you can see.. the surface looks dirty... seems like its too late in the season (phoenix) to do a acid wash... but somehow... something cleaned up a couple of streaks... so I m wondering if I adjust water chemistry to dissolve whatever is keeping the surface from looking like the clean, blue streaks..my numbers are FC 3.0.. PH 7.2... TA. 50.. CH 300.. CYA 40..Temp 80
garygaugler
23
Arizona
Ok... the 3.0 was in the am before I added FC... but I heard what you said about running the FC level at 8-9... can us tell me what CL means..? what can I do to reduce the calcium buildup... thanks..
garygaugler
23
Arizona
maybe a better question would be... what do I have to do to get the color of the bottom of the pool the same as it is in the stripe areas..
thanks..
Other Threads of Interest
