How tight should solid cover be?
jlt19
77
St. Louis, Missouri
We have the solid cover that came with the pool on. We put two tubes in and hung jugs of water around to keep it on. We didn't tighten it too much because we were unsure. Went away for a week and came home to this.
Should we tighten as much as we can? Leave some slack? DH is going to get a hand siphon (we have a pump but he wants to do this). 20191019_083538.jpg
Newdude
4,509
NY
Anytime you get rain/snow it gonna do that. Which doesn’t hurt anything. If you don’t want to have yucky stagnant water on top you can drain it with a pump or siphon. But most people get sick of constantly doing so and ultimately just leave it until it gets almost full before draining again.
jlt19
77
St. Louis, Missouri
That's good to know it won't hurt anything. That was my fear, that the water would pull on the sides too much and break the pool. I guess at some point it'll just sit on top of the pool water though.
I wasn't sure if we should try to make it like a circus tent with a tall middle spot and hope the water drained off (sort of like when you put a pole in the middle of a boat?)
I don't mind draining while it's 60 degrees. 0? Not so much.
Newdude
4,509
NY
that’s the idea that most people try for. More tent means less water can collect. But it will still collect with the water level below the skimmer. And the pillows rarely make it through the winter so although most people start with a bigger tent, most of them end up flat anyway.
Reactions: jlt19
Newdude
4,509
NY
everybody starts right and are gung ho before it gets cold out. Most people give up at some point and it freezes for a few months. once it gets slightly warm enough to care again, everybody shrugs and says ‘Meh, it’s been like that for the last 3 months now, might as well let it be for another month until opening’.
so if you let it be now, you’re just letting it be sooner. Cuz you’ll end up letting it be anyway.
Reactions: jlt19
jlt19
77
St. Louis, Missouri
In my experience if enough water collects it will the cover off.
I feel like a very important verb is missing here, lol.
I ended up buying the little giant and it's been great so far. I don't feel comfortable with it plugged in 24/7 (my own paranoia) so I've just stopped it once it's left a little bit. I like some water on there because it makes me feel like the cover won't blow away as easily.
Lisbek
48
Central Point Oregon
Yes you are correct. I meant to say rip or pull the cover off lol. I used home made bungee cards to secure it so it can flex as needed.
Reactions: jlt19
