How much water is in a Circupool RJ30+ cell?
dswwpb
76
West Palm Beach, FL
I'm seeing some calcium deposits on the plates so I'm going to clean my RJ30+ for the first time since installing it 5 months ago. I want to mix the acid solution beforehand but don't know how much water the cell holds. My guess is about 2 quarts. Does anyone know for sure.
Also the manual says the mixture should be 4 parts water to one part MA but I see 5:1 suggested here quite often. Which is correct?
dswwpb
76
West Palm Beach, FL
Cleaned it today. The numbers on the display are back to normal. Before cleaning, it was displaying about 1000 ppm lower than actual testing of the water in the pool. Now it's back to within 100-200 ppm of actual testing. FYI, the cell holds 34-35 ounces of liquid filled to the top, so 28 oz of water and 7 oz of MA gives you the 4:1 mixture that's recommended by Circupool.
Reactions: markayash
YippeeSkippy
14,628
Evans, Georgia
That seems like a lot of buildup for five months use!?
Remember that each time you clean it with acid you're removing some of the precious metal that makes the *magic* happen.
So its better to tweak your CSI to the negative side and avoid cleaning it as much as possible to maintain maximum lifespan of the cell.
Maddie
dswwpb
76
West Palm Beach, FL
Maddie
For the entire 5 months, the CSI has always been on the negative side.( -.1 to -.35 )
DeanP66
816
San Jose, CA
You might try cleaning it with just water from a hose only. I've cleaned my friend's RJ 45+ a couple of times and I've noticed that just a strong stream of water through a hose will often times clean it out just fine. That way you avoid the muriatic acid on the plates whenever possible.
dswwpb
76
West Palm Beach, FL
Thanks, I'll try that next time.
