How much salt to add? AquaRite Lights are Flashing.
martinezj1120
54
Michigan
So after a hot week and a lot of swimming, yesterday, we added some fresh water to our pool as the water level was lowering to get up to mid skimmer. Today, my new Aquarite ( < 1 month old) was light up Low Salt and Check Cell. I can't imagine the cell is dirty already but can inspect if needed. Currently reading 2500ppm and usually reads 3400 ppm
What is the optimal ppm for a SWG with a vinyl liner? Is there a calculator that helps with how much salt to add? Thank you
Latest test if needed
FC 4.5
PH 7.5
CC .5
TA 80
mguzzy
830
OV, CA
Is that the instaneous or average salt reading? I would go through the reset procedure to force it to restart the average salt reading and it should clear the lights too. If it happens again then there is something going on.
martinezj1120
54
Michigan
Rest it. My average salt reading is 2500 ppm and the instant is showing -3200 ppm. I cleared the "Check Cell" light and now only the "Low salt" light is blinking.
When I jumped in this morning, the water was noticeably less saltier.
Hootz
112
Rogers, AR
Consider a salt test kit to compare with the readings from your swg. Most agree the Taylor K1766 is the most accurate. Pool Math will help you determine how much salt to add once you get an accurate reading. The minumum FC is 3 and target is 5 with a CYA level of 70. You can find more information in the Pool School section.
mguzzy
830
OV, CA
Check that. After I cleared the Check cell light, I reset the Instant salt light now reading -3200 and both lights came on blinking.
which "both lights".. are you refering to? Please be specific. I don't want to assume and guess.
I think I might disconnect the cell and make sure there isn't something in the cell. just to make sure. Probably just a visual inspection at this point. It's brand new so acid washing won't accomplish anything. In fact before we go too far down the troubleshooting and repair road. Take advantage of the warranty support. just sayin'
Reactions: martinezj1120
martinezj1120
54
Michigan
Sorry. The low salt and check cell lights came back on.
I just ran a sample of the water up to the pool store for an independent test and the salt did come back at 2700 ppm.
mguzzy
830
OV, CA
So it MAY need salt. But get the salt test kit Hootz recommended. I once tried to corelate the salt reading on my controller with the pool store... they turned out to be way off and I over salted my pool as a result.
