How much glass media do I need to replace sand?
NudeyRudey
10
Sydney, Australia
Hey,
Changing the sand in my pool filter as I have never changed it in my 6yrs of ownership and it does not appear to working correctly.
I removed the multi-port valve off the top and I was expecting to see sand, but instead there is this red crushed brick like stuff (right side of pic 2nd pic). That is what I pulled out from right next to the centre pipe which goes down to the laterals.
When I reached in and pulled a handful out from around the edge of the filter tank, it was a mix of decaying leave and white gunk and some of the red stuff (left side of pic 2nd pic).
The red crushed stuff is not sand or glass and does not look like Diatomaceous earth either – well maybe the white stuff.
The filter is a ECOPURE 25 (pic of details in the link)
cheers
kimkats
48,182
Tallahassee, FL
Note to others-click on the filter and it will take you to his "stuff" pictures. Cannot call it sand at all! Have NO idea what it is. With you being on the other side of the pond it may be something your area sells.
I say it is a good thing you are changing it out. It will be interesting to see what it looks like when it is dry as well. What does it feel like?
NudeyRudey
10
Sydney, Australia
It's ZEOLITE, it says so on the label!!!!
My stuff is red in colour.
NudeyRudey
10
Sydney, Australia
hi,
Looking to change the media in my filter from zeolite to glass.
On the label it has Sand weight = 160Kg, Zeolite = 120Kg
How much glass media do I require and what is the ratio of course and fine glass that I require?
thanks
ajw22
24,982
Northern NJ
Pentair Intellichlor IC-60
Why not just use sand that has proven to last thousands of years?
ajw22
24,982
Northern NJ
The ”best” is nature’s own sand. Don’t believe the marketing hype.
Reactions: kimkats and proavia
