How much does a fiberglass pool shell weigh?
Aleforge
287
Wentzville, MO
My pool floated (posted about) and I am looking at this point on possibly renting a crane. But I am not sure how to figure out an estimate on how much my shell weighs though. It's about 20x14 with 5' deep / 3' shallow end.
Thanks
ajw22
21,116
Northern NJ
Pentair Intellichlor IC-60
You know the manufacturer of your pool shell?
Every fiberglass pool manufacturer has a spec sheet that shows exactly how much it is supposed to weigh. Depending on the size of the pool, most shells weigh between 2000–3500 lbs.
Aleforge
287
Wentzville, MO
The only thing I "think" I have is the original broucher from 20 years ago. But I don't think it has much information in it. The owners didn't leave much outside of that and a very simple hand scrawled receipt. Is it due to thickness? I figured there might be a calculator somewhat using dimensions but I guess not.
ajw22
21,116
Northern NJ
Just error on the high side. Get a crane that can lift 5,000 to 10,000 lbs.
gingrbredman
184
Chicagoland
Fiberglass
Pentair Intellichlor IC-40
My 14 x 30 shell weight in at just about 3k lbs. Just had it dropped in last month, and the crane that did it barely broke a sweat.
