How much DE for Pentair filter? (Pic attac
Jimrahbe
16,975
Bedford, TX
4047,
That would be zero DE.. :mrgreen:
Just to double check.. I assume that the output of your pump is plumbed directly into the input of your filter, without going through any valves.. Is that correct?
If not, show us a couple of pics of your equipment pad.
Reactions: mendez4047
mendez4047
Active member
Apr 7, 2015
42
Southern Cali
4047,
No DE? Hmm... what was I thinking. I bought a bag of DE too.
Here is the pic of my equipment:
mendez4047
Active member
Apr 7, 2015
42
Southern Cali
Since we are on the subject of my pool equipment, I'm doing my own start up (owner builder).....Do these pipes need to be cut for the spa air suction? (1 pool/spa pump and 1 booster pump)
wireform
In The Industry
Aug 15, 2017
1,216
Spring Valley, NY
You can use it a little at a time even with a cartridge filter to polish the water as a final step after you have stabilized the chemicals and you're smooth sailing. I have 2 pools with cartridges and use it.
Jimrahbe
16,975
Bedford, TX
Yes, cut both those pipes
Brian,
@bdavis466
Ok... I'm here to learn like everyone else... Please tell me about the pipes and what they do.. I assume this style of spa does not use a blower, is that correct.
Why are there two pipes and not just one??
Appreciate any feedback so I can understand what is happening.
