How long to run variable speed pump
Dawnamie
12
Kauai
Hayward Aqua Rite (T-15)
Question
How long should I be running my Hayward 2.7 hp variable speed pump? speeds? I want to decrease my electric use if possible. I have read some people run there pump 24/7 2-4 hours high speed 4-8 medium and the rest of the time low. Is that really necessary?
My pool is 30,000 gallons,SWG water temp 78
Jimrahbe
25,988
Bedford, TX
Dawn,
If you have a SWCG you only need to run your pump at a speed that closes the flow switch and for long enough to generate the amount of chlorine your pool needs. Most likely that amount of time will also keep your pool well skimmed.
Other than that, you don't need to run your pump at all.
There is almost never a reason the run the pump faster that what makes the flow switch close. Unless you have an in-floor cleaning system or some massive waterfall you want to run or run a water-powered cleaner..
Dawnamie
12
Kauai
Thanks Jim. No waterfalls or anything fancy just your basic 16x40 rectangle also no heater. I’m a bit unclear on what speed my pump needs to be at to have the SWCG switch on. I set my SWG to 20% and have it running from 9-5 and that’s keeping my Chlorine at 4ppm.
Dawnamie
12
Kauai
Doesn’t seem like there is a definite answer on what percentage/length of time to run SWG, seems like people just play around until they find the right spot to produce the proper levels. Same with the pump. My pool is very new so I’m learning all I can to keep my water clear and levels correct.
Jimrahbe
25,988
Bedford, TX
Dawn,
Not at all true. Cell's pump out a specific amount of chlorine over a 24 hour period, based on the cell size. Pool Math lets you determine exactly how long your pump needs to run.
Tell me what specific saltwater system you have and what size cell you have.. I know you pool is 33K gallons.
You can tell what speed to run your pump by slowly increasing your pump's speed until the cell or control panel indicates that you have good flow.
It is not at all guess work.
