How long is the average life of a vinyl liner?
adl6009
67
Long Island, NY
Over this winter I lost about 1/2 the water from the pool. Right now the water level is just above the light. I couldn't see any obvious cause, but it was hard with the safety cover only partially removed. My first liner lasted 20 years, this one is about 10 years old. Just wondering.
zea3
14,096
Houston, Texas
If the leak stopped just above the light that is most likely where your leak is located. Check corners and seams around that height for leaks, also check around the light itself. Use leak detection dye to check for leaks. Liner may be fine. Honestly its hard to tell without seeing and touching it. Low pH levels can shorten the life of a liner, as can UV exposure.
TheRaven
54
Fleetwood, PA
Liner lifespan depends big time on conditions and care. That said, the liner I just replaced last summer was 13 years old and was completely neglected for 6 of those years...and I mean pool uncovered and untouched year round for six years kind of neglect.
I was quoted $3500 for liner replacement on my 14x28 pool a couple years back before I decided to completely renovate the pool...that quote was from the most highly recommended guy in the area though, so not a cheap option by any stretch, and it was for a Merlin 27mil "premium" liner too.
Pool_Medic
In The Industry
Apr 1, 2018
1,554
Bangor Maine
IMO if it’s a puck pool and new liner you will be lucky to get 10 years, reason being puck pools are almost always acidic which causes liners to get brittle prematurely.
SWG pools I am seeing 12-15 years, because they tend to run over Ph of 8 a lot.
Joshii
255
What did you do to completely renovate the pool?
TheRaven
54
Fleetwood, PA
Essentially we built a new pool. It was a 14x28 grecian, 5.5ft deep end. We completely removed the steps and step-side walls and expanded out in a lazy-L shape, adding 14ft to the length of the pool. Dug out the deep end to 8ft, added a skimmer and return, added lighting, and all new equipment. Also fixed a giga-ton of terrible concrete work along the way.
Joshii
255
nice! How was the price, compared to starting with level ground and building a pool where there wasn't one before?
TheRaven
54
Fleetwood, PA
Roughly half. And it would actually have been a lot better than that if not for the need to remove 6-10ft of poorly laid concrete all the way around the pool. Stuff was 8" thick in spots. Concrete is a funny thing - done right it's awesome, but done wrong you can end up with an 8" thick slab that weighs as much as a planet yet is about as strong as a half inch thick sheet of ice.
Reactions: Joshii
