How I Ballance my Chemistry - Crystal Clear Water
Agua
10
Taylor Mill, KY
I have a 22,000 Gallon vinyl liner pool in Northern Kentucky. I check my chlorine every evening and add 10% Chlorine to bring the level to 8 ppm. Over the next 24 hours the chlorine level will decline by 2 - 5 ppm. I usually add between 50 oz to 100 oz of 10 chlorine per day. I have crystal clear water, don't add any other chemicals and never shock. I have tried lower chlorine levels but have had problems with algae. I have a very low Cyanuric acid level since I don't use Trichlor Pucks. The Ph raises with this regime so I need to add acid about once a week and occasionally raise the alkalinity. Remaining chemical levels do not fluctuate enough to worry about.
IceShadow
1,742
Milwaukee, WI
What are you using to test? Can you post a full set of test results?
Based solely on your description I would say you’re probably increasing TA when you don’t need to, and your CYA might be a bit low, but I don’t have any numbers to base that on.
mknauss
27,152
Laughlin, NV
Welcome to the forum!
Without test results, we have no idea what your pool water chemistry needs.
Post up your test results.
critter783
16
Melbourne, KY
Hey welcome to the forum! I'm just across the Licking from you but grew up over in Kenton Co. For most of July, I've been adding 64 oz of 10% from Walmart every day.
It's funny you mention that about the PH and adding acid. I had a new liner done in June and filled from my garden hose. TA was 70 on the fill water, and my PH has been sitting at 7.4 - 7.6 all summer. I haven't had to dose with acid at all yet.
Agua
10
Taylor Mill, KY
You sound like you are doing about the same as myself. If I were to average it out I would use about 80 Oz a day. I buy mine from Remkey at good price. I am familiar with Melbourn. We used to have a river camp at Oneonta just down the road. We would always stop at the Melbourne Mall.
critter783
16
Melbourne, KY
That sale coincided with a new location grand opening here back around the 4th. I checked at lunch and they had almost 100 units listed in stock - all sold out by 6PM.
