How do we manually open coverstar auto cover with broken roll-up tube (drum)
Serious1
110
NE
Our aluminum roll-up tube is corroded and parts are hard to come by right now and we'd like to use the pool. How can we manually remove the cover ourselves so we can use the pool (our cover is encapsulated if that makes a difference)? We realize we'd have to leave it off until a new drum came in. The new roll-up tubes are apparently made of plastic so they don't corrode. Luckily it didn't rip the cover when it fell apart. Thanks!
Serious1
110
NE
unfortunately we can't do that since the drum can't move. We're thinking we need to pull the drum out of the cover box, detach the fabric and then roll it back slowly and gather it.
bmoreswim
Platinum Supporter
6,411
Central MD
Once the drum breaks I’m no help. I’ve manually opened mine with a breaker bar with a good drum.
Serious1
110
NE
In case someone else has to do this...we pulled the corroded drum out of the cover pit with the liner attached. We then pulled the cover back by hand (one person on each side pulling evenly and then decided we should wrap it up around the drum so that the storms/wind can't pull it up. It pulled quite easily by hand if you grab the cover near the edge. We'll leave it off until the new roll up tube comes in.
