How do I use the app
hmvjos
1
Houston, TX
Pentair Intellichlor IC-40
I am a new pool owner as of Jan. I purchased the Taylor test kit to check my water. I now have the numbers but not sure how to plug them in the app? When I go to "pool math" it shows me how to download the app but I have already done that...sorry feeling really stupid right about now.
mknauss
37,239
Laughlin, NV
Fiberglass
Welcome to the forum!
On your phone, open the app. You will need to login using your Troublefreepool.com account Member name and Password. You then go to Settings (gear icon) and set up your pool. While there, enable Sharing so we can see your Poolmath data.
Once you have done that, touch the + sign at the bottom, select Log Test Results, and enter your test data.
I suggest you read ABC's of Pool Water Chemistry.
Reactions: Casey
PoolGate
5,593
Damascus, MD
Jandy Aquapure 1400
You should have a "+" on the bottom to add a new log. Then select "Log Test Results".
Leebo
Admin
10,509
Eastern Ohio
Give this video a watch. Granted it’s boring and poorly done, but it should help you out.
Reactions: Casey
