"Hotwire" my pool pump?
You can bypass the relay if necessary.
There's a 6 terminal terminal block.
There should be a brown wire from terminal 3 to the relay and a brown wire from the relay to terminal 5.
There should be a blue wire from terminal 4 to the relay and a blue wire from the relay to terminal 6.
When the relay closes, the power goes from terminals 3 and 4 to terminals 5 and 6.
To power directly, you can remove the relay wires from the terminals and run a wire directly from 3 to 5 and a wire directly from 4 to 6.
Note: Don't do anything unless you understand exactly what you're doing and can verify that the wiring makes sense as described.
There's no guarantee that the wiring was done according to the manual.
Reactions: SinistrV6
