Hot Tub cleaning
PascagoulaPool
8
Pascagoula, MS
Anyone have any suggestions regarding removing small debris from the bottom and seats in a hot tub. The guy that installed the electronics for my pool/hot tub recommended that I get the underwater rechargeable vacuum from Home Depot. I find that it is a bit unwieldy to use and when I use it on the steps it seems like it is even more difficult. I also have a sun deck that seems to collect debris but I can typically brush that into the main part of the pool, but it takes multiple passes with the brush to get things pushed into the pool. If I had something that could vacuum but was not so big or heavy it would be ideal.
5tan
19
Canada
QuickVac QuickVac is the smaller version of the QuickDrain, both work by via manual/mechanical siphon action. Or cut a 4L jug of vinegar and use the flat edges as a scoop.
