Happy Friday,
The IG vinyl pool pictured below is in my back yard. I'm adding an addition onto the back of the house and it will get really close to the pool steps seen in the picture. I don't want the pool to limit how much space I can add to the house (homes are valuable around here - pools not so much, unfortunately), so I'm thinking about having the Pool's steps removed to give me a few extra feet of real estate.
Questions:
1) What is the process to remove pool steps and replace it with a vertical wall that's the same height as the rest of the shallow end? (The pool will then be a rectangle). Estimated cost or man hours?
2) How easy/hard is it to add steps to the corners to the left and right of the existing steps (shallow end)? Again, estimated cost or man hours?
3) The pool pad will have to be removed while the home construction is taking place, meaning return and supply pipes to the pool will be cut. What can I do to prepare for this? The inground pipes are black poly.
4) I'm thinking of adding a wooden deck between the new addition and the shallow end of the pool, to "join" the two structures. The elevations are relatively close, so it'll be a step down from the house and then another step down to the existing concrete deck. What do you all think?
Thanks and I'll update the thread as home construction begins!
Questions:
