High TA
PrTexas
6
Houston tx
I'm using the TF -100 kit and am getting high TA levels. 180 double checked, now today 160 double checked. I took a sample to pool store just for a 2nd opinion and they read it as 100. I've read directions and using the 25ML test but I feel like something is wrong. Appreciate some advice.
FC 5.5
TC 0
TA 160
PH 7.8
CH 300
CYA 60
mknauss
22,749
Laughlin, NV
Trust your testing.
TA testing can have an issue with static electricity making the droplets smaller. So read Total Alkalinity - Trouble Free Pool for that.
I assume the pool store gave you 'adjusted' alkalinity. They take 1/3 of the CYA they test at and take it off the Total alkalinity. Poolmath manages that for you when using TA for pH adjustment, etc.
PrTexas
6
Houston tx
Trust your testing.
Great thanks! I'll look over the info and try again.
Richard320
22,069
San Dimas, CA (LA County)
I would trust yours any day. But if you want to play it safe. maybe only target 7.6 pH when you dose instead of 7.2. Then you won't overshoot out of the safe zone.
If you do overshoot, you know the TA reading was off. If you hit it right, you were right.
Reactions: PrTexas
