HIGH SALT READING IN PEBBLE TEC POOL
rmklaw
108
I hd my plaster pool re built with Pebble Tec 1 1/2 years ago. The old pool was saltwater. However, After the PebbleTec resurfacing I never used salt and have been using chlorine. I have a strange problem. The last check for chemistry showed everything normal, but the salt level is 2100.
How can salt level go that high if I never used salt after the remodeling of the pool? Could old salt leached from the gunite after the pool was Peble Tec?
Any help in resolving this puzzle would be appreciated. I sometimes use water softener water for topping up, but the salt level from the tap is under 200 ppm. Thanks.
ajw22
19,487
Northern NJ
Liquid chlorine contains salt. If you are using 10% LC then for every 3.6ppm of FC you are adding 5.6 ppm of salt.
If your pool uses 3ppm of FC a day then in 500 days you will have added over 2,500 ppm of salt.
Jimrahbe
18,840
Bedford, TX
Richard,
Why did you not stay with a saltwater pool... :scratch:
If I built another hundred pools they would all be saltwater pools.. :mrgreen:
rmklaw
108
ajw22: That could be the answer. I have been using liquid chlorine since the remodel. Jim, I stopped the salt system after the remodel because I was concerned that the salt system was causing the staining I fought for years in the old plaster. Having said that, PebbleTec tells me that the salt system should not cause staining in PebbleTec, provided chemicals are balanced. Accordingly, I am going to enable again my Poolpilot Total Control. I probably will need to replace the cell. It has 41,000 AH and over 6 years. I run a test and it shows at 25% 0volts and 6.5 Amps.
rmklaw
108
Yeap! Tomorrow I am going to disable the Chlorine feed of my Intellichem and add the necessary salt to get the Total Control going.
bdavis466
Platinum Supporter
Aug 4, 2014
5,529
San Clemente, CA
Acid has a ludicrous amount of chloride in it and I imagine you're going through a lot of acid. Almost every chemical you add to you pool has some sort of salt in it.
