High Pressure low return
Apr 15, 2018
2
0
Sherwood Ar
#1
Ok I have strong suction and and my pressure gage sits at 15 psi. After approximately 10 minutes or so the pressure climbs to 22 psi at the multi-valve pressure gage for the filter, and the return jet pressure drops to a very faint return to where the water isn’t even moving. I can’t seem to find the issue. My pump stays primed even at 22 psi with no bubbles in the pump filter. However if I change the multivalve to recirculate and it sits at 13 psi, I monitored it for approximately 1.5 hours and the psi doesn’t move. I’ve replaced the filter sand, the fitting from pump to multivalve, the multivalve itself, and the valve is new. I’ve checked for leaks on the pipes that are above ground And it’s not leaking water anywhere. It’s a Hayward S200 filter and a Hayward super 1 hp pump. Any help would be gratefully appreciated.
Texas Splash
Hello and welcome to TFP! :wave: It sounds as if water flow is being restricted in the filter, possibly from catching some debris or materials. Can you post a full set of water results for us? Results from a Taylor K-2006C or TF-100 would be best. That would be step 1 so we can rule out the early stages of (clear) algae. In the meantime, make sure to include all of that equipment stuff into your signature. That will help a lot later as well. Nice to have you on the forum.
Jonathan22
2
0
Sherwood Ar
#3
If any one was curious to what the issue was. I disassembled the filter again and the lateral holder assembly bottom had broken and when it was pumping the piece would cover up the return hole and cause the issue. Good luck and hopefully this will help someone.
