High pH, low CYA
alosito
100
Simi Valley, CA
I am starting the season, and I found out that my pH is 8.2 while CYA is 25. What would be the recommendation to balance the water in this case?
Texas Splash
33,620
Fiberglass
CircuPool RJ-45 Plus
You want to lower the pH with muriatic acid to around 7.6-7.8. That should help to control scale. Then you want to increase the CYA to about 40 this time of year for a non-salt pool in your area. Use the sock-soaking method to soak and dissolve the stabilizer. Be sure to keep the FC balanced to the new CYA level as noted on the FC/CYA Chart to prevent algae.
Kevinr14
295
Chandler, AZ
Just curious, could you add the CYA and then adjust PH after since the CYA will bring the PH down a little?
Texas Splash
33,620
Fiberglass
The effects on pH from the CYA will be negligible. Nothing like muriatic acid. I would just consider them separate.
Reactions: Kevinr14
alosito
100
Simi Valley, CA
How much muriatic acid and stabilizer should I be adding?
