I just filled my new pool a month or two ago and the alkalinity has been around 170. This is what my fill water is, so that’s logical. pH has not been a problem, in fact, it’s pretty slow to rise... If I lower it to 7.2 with MA it will take 2 or 3 weeks to get up to 7.6 or 7.8. My plan has been to just let it slowly lower over time adding MA every few weeks to keep the pH down, but at this rate it will probably be months or longer before I see a significant change in the TA.
I’m reconsidering that plan because I just added a Circupool RJ-30 and I know that high alkalinity can be a concern for the salt cell. Should I be concerned about my alkalinity level affecting the cell? Would I be better off trying to aerate the pool more effectively so I can use more MA to bring down the alkalinity faster?
FC - 8.5
CC - 0
pH - 7.4
TA - 170
CH - 170
CYA - 80
Salt - 3400
It’s worth noting that I have tried the “wiping the reagent bottle tip with a damp cloth” trick and I believe this is an accurate TA number.
FC - 8.5
CC - 0
pH - 7.4
TA - 170
CH - 170
CYA - 80
Salt - 3400
