High Filter Pressure
kimkats
41,288
Tallahassee, FL
We suggest backwashing or cleaning a filter when it's pressure gets 20% over the clean pressure. Here is a great write up about DE filters:
With new plaster you will need to clean the filter more often as the plaster dust does a number on the filter. Keep brushing the pool and keep the chemicals level and your plaster will cure and you won't have to worry about it as much down the road.
Texas Splash
Don't forget to update your signature as well next chance you get. We scan that info at every post to help make replies more productive and accurate. Once you backwash/recharge, make sure to write-down your new (clean) PSI reading so you can compare it later to a potentially dirty (high) reading.
