high CYA ok?
Follow the FC/CYA chart. At CYA 100 your FC target is 11-13 with a minimum of 8.
Reactions: Mdragger88
To add to what @ajw22 said - if you’re still using your chlorine feeder & pucks - stop 🛑 or the cya will only climb higher thus needing a correlating higher fc level.
Stick with liquid chlorine if its too cold for your swg.
Also do the diluted cya test if you haven’t already- your cya may actually be higher than 100 & you’ll need to chlorinate accordingly.
Step 8👇
