Newby here and my husband and I are not sure what to do. In reading I see we need to deal with cya to get everything in line and convert to liquid chlorine. Will need to buy as we haven’t used before.
In ground pool 11,500 gal gunite Just got the K2006c test kit. Our cya is close to 175. Our fc is 4.8 ph 7.6 Ta 180 Ch 250. Had been using shock and tabs. We need to drain water and refill quite a large volume but we have never done it and want to be sure we do it correctly. We have 2 skimmers, and a main drain valves at equipment pad with back wash to sewer line. we will need to drain quite a bit but reading about below skimmer lines and pump prime and not sure what steps to follow. we have algae on steps and side. Can’t get the pictures of equipment to load. The filter and pump info in my signature. We are on city water.
