Hello, I read a bunch on here yesterday and really appreciate all of the help thus far! Thank you contributors!
We purchased a home in MN with an in-ground chlorine pool and I'm learning way more than I thought I would need to already. I read up on SLAM and related topics but I haven't seen much on reducing COPPER levels. We are extremely high in copper; 3.3 ppm and had extremely low/immeasurable ph and low TA. I've done the following over the last few days:
Initial #'s 5/11/20:
FC: 0.58
ph: 6.5
TA: 27
CH: 62
CYA: 45
Copper: 3.3
Iron: 0.1
Added on 5/12/20:
20lb. Alkalinity UP
2lb. PH UP
brushed
2 gallons of 12% liquid shock
- Became cloudy immediately, lasted for 24 hours, and I started to see things settle to the bottom after 12 hrs.
- Clear at 36 hrs, blue dusty stuff (very fine) settled at bottom.
Numbers on 5/13:
FC: 8.37
ph: 7.0
TA: 90
CH: 53
CYA: 44
Copper: 3.3
Iron: 0.1
5/14:
- water is clear
- vacuumed up blue dusty stuff
- slight blue ring on some of the sides at water level.
- Added 2 qt. of METAL MAGIC
- water is still clear 2 hrs later.
MY QUESTION IS:
- can you recommend next steps? Do i need to SLAM?
- Should I increase ph now? or check copper again first?
- Do you think that copper was the blue dusty stuff that settled since the ph and TA came up?
....I'm going to get it tested again (still don't have my own kit yet)
THANK YOU!
FC: 0.58
ph: 6.5
TA: 27
CH: 62
CYA: 45
Copper: 3.3
Iron: 0.1
Added on 5/12/20:
20lb. Alkalinity UP
2lb. PH UP
brushed
Numbers on 5/13:
FC: 8.37
ph: 7.0
TA: 90
CH: 53
CYA: 44
Copper: 3.3
Iron: 0.1
5/14:
- water is clear
MY QUESTION IS:
THANK YOU!
