Hi,
I just got started learning about all of this and have been trying to balance out our stock tank pool which is 700 gallons.
It seems the chlorine level has been really high, I have to dilute it to get an accurate reading and it appears it's at 20ppm.
We are using the 3 inch clorox pool tablets which are 99% trichloro. I guess I have to just take out the float and use something to reduce the chlorine?
Do smaller tablets like the 1 inch introduce less chlorine?
I have some bioguard chem-out which is sodium sulphite, I imagine this could help reduce the chlorine in the near term?
I also have some doheny's non chlorine shock which is potassium monopersulfate which I guess could also help.
On top of all of this we got white water mold and it seems to be still mildly present, I cleaned everything out several times and shocked the pool with pool essentials 4 in 1 shock which is 45% trichloro.
The white water mold only seems to show up as very tiny thin threads when we are using the pool and then is completely gone once we are out.
I used a poolmaster 5 way kit to determine that ph is at 7.2 or slightly above and alkalinity is at 110 ppm.
Sorry if this is too much or not enough info but I'm just looking to see what the best and simplest way forward is.
Nick
Nick
