I'm having a problem with slightly green tinged water in the deep end.
FC <.5
TA 130 (added muriatic acid to lower)
PH 7.6
CYA 41 (added stabilizer to raise level)
Salt 3400ppm
CH 455 (I only know this because pool store tested water, I never test for CH)
I can't seem to make chlorine. I had SWG raised to 75% and still only have less than .5 FC. I turned SWG off and added a bottle of bleach, but pool is still tinged green (I haven't test FC since adding bleach about an hour ago).
I've also noticed some rust spots on the liner. Could high CH be causing the rust and/or the green tinge? Not sure why I can't raise the FC though. I have a gas heater. Pool store said high CH could cause rust on heater, etc. Not sure I believe anything they say.
FC <.5
PH 7.6
Salt 3400ppm
