High CH.....I want Low TA and Low PH, right?
jp4LSU
91
DFW, TX
Pentair Intellichlor IC-40
A couple months back I had calcium snowflakes pooling the in bottom of the pool. CH was 650ish and TA was 110. I got the TA down to 65. The snowflakes have stopped but I do have floating scale on the surface. I assume that is calcium.
So I went to a mom and pop pool store I buy acid from and he said my TA is too low and should come up with the high CH when I mentioned the little floaters I had.
To keep the calcium from scaling and creating snow in the water, I want low PH and be on the low side of TA range and keep my CSI at 0 or neg, right?
Texas Splash
41,585
Fiberglass
CircuPool RJ-45 Plus
Yes and no. :) To help prevent the accumulation of scale to begin with, yes, you want a slightly negative CSI. If the CH is beginning to get too high, especially in the summer with higher water temps, you compensate by closely managing the pH & TA to keep them a little lower. Getting the TA down to about 60 is perfectly fine. The mom & pops store is probably just referencing generic industry levels of 80 - 120 which is not a good thing to do.
But when you see flakes it probably means you had scale already accumulating, probably in the SWG cell, and when you lower the pH and TA it released that scale from the SWG causing the slakes in the water. They should eventually subside.
jp4LSU
91
DFW, TX
Thanks Texas Splash for confirming my thought process. TA is at 65, I'll get it down to 60 and maintain PH in the between 7.2-7.6. Now over time, that TA will eventually get too low and I'll need to add baking soda, right? I've only had to deal with high TA up until this point.
proavia
3,955
Chandler AZ
What test kit are you using?
Post a full set of current test results from one of the recommended test kits.
I see you have a SWG - is it operational?
Fill out your signature with your pool, pool equipment (including manufacturers and model numbers) and test kit info.
This assists us in providing help based on your pool without needing to ask you each time.
