Hello- I just recently purchased the K-2006c test kit. I use to take my water to pinch a penny and they pretty much always said everything was perfect except maybe a little acid needed to bring down PH. My pool was replastered last year May. It’s has a pebble tec St. Lucia Pearl color. Since the pool has been done I notice after several months what appears to be a fine layer of scale all over bottom of pool. When I asked the pool company they told me it’s “ frosting over”. I was told with darker finishes that I need to keep Ph on lower of range to prevent this. No other instructions. After some posts on another Facebook group I’m told it’s calcium. So, I just did water test and CH is 700 & CYA is 90. I know best way to reduce is drain and refill. My question is. I live in Florida. We are about to hit rainy season where we can pick up 2-3 inches of rain per day during afternoon storms. Will these numbers come down naturally with all the rain we get in then next few months or should I drain and refill now? Also-‘once my CH and CYA are within range, will the scale gradually go away?!
Can the 4 in 1 all purpose chlorine tablets by suncoast be causing my CH to climb?
