High Alkalinity / Lo Ph
Hi.
This is my first experience with a pool. The house I purchased has a 18 by 52 round above ground pool. I cannot seem to balance the pool. Most of the readings are good besides I have Hi Alkanlinity /Lo Ph. The pool is extremely cloudy but blue.
Can anyone offer any advice
Thanks
Any
mknauss
29,831
Laughlin, NV
OK -- how did you get those numbers? It is chemically really hard to have that low a pH and that high of TA.
Aeration will raise the pH.
If the pool is cloudy it needs to follow the SLAM Process
wireform
In The Industry
Aug 15, 2017
1,308
Spring Valley, NY
Amy,
Hi, possibly your not doing the TA yest properly. Look in pool school as TA testing is tricky. The TA may actually be less and you were not getting the full droplet off the tip therefore ending with more drops bringing the count higher.
Richard320
23,634
San Dimas, CA (LA County)
FAC 1
TCI 5
Alk 240
PH 6.2
TH 250
Cya 0
If these abbreviations stand for what I think, you have 4 CC. That, combined with cloudiness, tells me something's growing in the water. The pool may not be green yet, but it's not far away unless you do something about it. High alkalinity won't cause cloudiness, nor will it cause any health problems. All it will do is tend to push the pH up, which is what you want.
I must echo what Marty wrote, asking the source of those numbers. If they're from the pool store, they're probably wrong. And even if they're right, you won't be able to depend on their testing during a SLAM Process, which is your next step.
mknauss
29,831
Laughlin, NV
Sadly, test strips are not fine. They are inaccurate, non repeatable, and do not test to the accuracy you need.
To clear your water you will need to follow the SLAM Process.
Your issue is, you live in Canada. And it is difficult and expensive to get a proper test kit in Canada.
We can guide you on getting a proper test kit. Or you can drain the bulk of the water from the pool and start over. That will most likely clear things up but this will all occur again without a proper test kit to manage your water chemistry.
So here is the whole story. After the winter and the water unfroze it’s was green. Someone told me to use green to blue so I could see the debris at the bottom. It turned blue but I could not see the bottom. So I shocked the pool and followed instructions that I found online.
I can see tiny little white particles floating all through the water
mknauss
29,831
Laughlin, NV
If that is the HTH Green to Blue stuff it is Cal Hypo followed by flocculant.
Can you vacuum to waste? The white particles may be calcium.
mknauss
29,831
Laughlin, NV
OK -- once you get the bulk of the floc out, then you would be best to drain the pool to 12-18" from bottom and start over.
Never use floc. More mess than it is worth.
