- Sep 10, 2019
- 85
- Plaster
- Pentair Intellichlor IC-60
Over the last couple of weeks, my pool seems to be using more acid. Over the last 2 weeks, it has consumed nearly 2 gallons of acid. I use an Intellichem system so its pretty easy to track usage because of the tank. I have it set to maintain at 7.6 but the system is having trouble keeping up and is even reaching the maximum daily dosage, which never happened in the summer. My first thought would be that my TA is out of whack (like really high).
I double checked my pH sensor with my k-2005 kit and its close. The readings today were:
pH = 8.0
TA = 80-90 (color changed initially at 80 but took 1 more drop to fully change)
CH = 330
Temp = 55
Does 2 GALLONS over 2 weeks seem high?
pH = 8.0
CH = 330
Temp = 55
