Hi! Question about slamming pool.
Calalily63
3
Springfield, Missouri
I live in SW Missouri and have a 5000 gallon summer waves 15' round pool. All of my pool levels have been spot on until this week. It's been in the 90's and I haven't felt well, so the pool was a little neglected. I was adding 6-8oz of liquid chlorine at night, but missed a night or 2 and now my pool won't hold the chlorine. I do keep the pool covered during the day since I work and no one will be using it. I added a cup and half of liquid chlorine last night because both the FC and TC were zero. My current readings as of 7 am this morning with a poolmaster 5 way test kit and aquacheck 7 strips are as follows.
PH 7.6
FC 2.0
TC 1.0
TA 190
CYA 0-30
HARDNESS 250
I noticed when I cleaned the filter that it was a gray/green, but pool is clear (does smell like chlorine when I first take the cover off) and I don't see any tell tale signs of algae. The chlorine issue just started this week. It was staying about 3ppm and I think the TC around 1 or 2ppm.
Should I slam it or add just enough liquid chlorine to get the FC up to 3-5 ppm? Oh and it's been 95 here all week. Pool is partially under trees (another reason I keep it covered when not in use) , but does get about 6 hrs full sun.
Calalily63
3
Thank you for for the links to the cheaper options. What can I do until I can start slamming the pool to keep it from turning into a swamp? At this point, I would prefer to not have to drain the pool because I probably won't refill it. We usually take it down right after labor day and that's only 6 or 7 weeks away.
