Hi everyone. New pool owner in So Cal.
zea3
12,634
Houston, Texas
Hi! Welcome to TFP! We are happy to help you learn about caring for your pool. Feel free to ask any questions you may have.
Mrmarkus
6
Rialto, CA
Hi everyone. I just started up my pool Thursday afternoon. Hope this goes smoothly. Added 1 gallon of Instant Conditioner, 320 lbs of salt, ran pump 24 hrs., then turned on SWG last night for 8 hrs overnight. Water was clear until this morning. Slight green tint. Took my first water sample to Leslie's this morning and was told to add Stain & Scale, then 2lbs of dry acid to bring down pH from 8.0 and then 1/2 gallon more CYA as I started low anyways with 1 gallon. Not registering chlorine or CYA. Hmm. Salt registered at 3,500. Was told not necessary to drain at this point, just follow their steps to get balanced. I added the S&S with pump and SWG on for 4.5 hrs. Will add dry acid now starting with 1lb for 4 hours then repeat until it's time to add CYA. Does this sound correct? If anyone has questions about the install, let me know.
