Here We Grow Again (the algae talking)
SPKNout4CHRIST
262
Goldsboro, NC
I have gone through the TFP process before and am sort of excited to do it again - is that weird?
My pump went out during Hurricane Matthew in October, so my water has sat since that time - enough said.
New pump, SWG flow switch, and refreshed T-100 reagents and I am ready to go. My numbers from today are posted below. This is after allowing the pool to circulate for 24 hours. I will be using the pool calculator to get info, but where should I start? pH? Thanks in advance! I will be sure to keep pics posted along the way!!
FC = 0
CC = 0 (I tested this more than once as I know it cannot be true. Is pH throwing it off? Something else?)
pH = 8.2+ (bright pink)
TA = 70
CH = 25
CYA = 0 (tested twice, never lost sight of the dot; I did have to use a sump pump to drain quite a bit of water after the hurricane and ended up putting some back in there recently)
jblizzle
43,238
You want to use our PoolMath (not the old pool calculator.com which is not maintained).
I would get 30ppm of CYA dissolving, then lower the pH to the lower 7s, and SLAM away.
jblizzle
43,238
Absolutely, gets the socks of CYA dissolving, then go ahead and add the MA to lower the pH. Once in range you can start the SLAM assuming your CYA is at the target (even though it is still dissolving). If you massage the sock enough, you can get the CYA to dissolve in only a day or so.
jblizzle
43,238
CC is a byproduct of the FC breaking stuff down. You have not put any FC in the pool. Plus CC just does not always show up just because there is algae ... which is why there are 3 criteria to stop the SLAM process ;)
SPKNout4CHRIST
262
Goldsboro, NC
Although we are several days past my "start", it is really day 2 of the SLAM as I have been adjusting the pH, cleaning the filter, etc. until now. I added bleach yesterday around 7pm and cleaned my filter grids just before that. See the before photo below of the grids. I was so anxious to get it all back together I forgot an after photo of the grids ;)
I added enough bleach to get me to shock level. When I rechecked everything this morning the filter was due a backwash and the FC was at 6.5. I added enough bleach to get back to shock level and will recheck ASAP to keep it as close to shock as possible. As you can see below, the water turned into a nice teal overnight - and doesn't quite have that swamp smell any longer!
Morning Numbers:
FC = 6.5
CC = 1.0
Filter prior to cleaning grids
Steps Morning of Day 2 (12 hours in)
Deep End of Day 2 (12 hours in)
Richard320
22,762
San Dimas, CA (LA County)
Excellent!
Inside the ladder rails and beneath the rungs are common hiding spots for algae. Be sure to brush them. If you can pull the ladder out, even better. It's probably held in with a wedge, exactly like the gooseneck on your bicycle's handlebar.
SPKNout4CHRIST
262
Goldsboro, NC
Thanks for the tip! I will be sure to get that cleaned thoroughly!
SPKNout4CHRIST
262
Goldsboro, NC
Making progress! The filter is continually reaching its backwash pressure, so I have been keeping it backwashed and refreshed as much as possible. Keeping the FC up and brushing every day so far. I plan to vac either today or tomorrow to help get out some of the foreign objects! CC is remaining 1.0 for now. See updated progress pics below!
Steps at the End of Day 2 (24 hours in)
Deep End at the End of Day 2 (24 hours in)
Keeping a check on the numbers!
Steps Start of Day 3 (36 hours in)
Deep End Start of Day 3 (36 hours in)
SPKNout4CHRIST
262
Goldsboro, NC
Update time! I can see the bottom in the shallow end and can start to see the bottom in the deep end. At least I can see what I am vacuuming now!
I do have a question, though. I noticed wrinkles (see pic below) in the shallow end. They were not there at the end of the summer. What could have caused them? Should I do anything to try and remove them? Thanks in advance!
Day 8 - Steps
Day - 8 Wrinkles/Shallow End
